l400 cv joints
madmazda
Vehicle: 1994 l400
l400 cv joints
Post by madmazda »
Hello all I was wondering where one buys a set of CV joints???? please and thank you
l400 cv joints
I just got all inner/outer CV boots from Mardy at AmazingAuto. I bet he's got what you need or any of the other vendors... Good luck!
Mr. D
Mr. Flibble
Re: l400 cv joints
Post by Mr. Flibble »
You can buy full CV setups with boots for a 1995 3.5 Litre Montero in the US for about $90 USD or less. Since you have to remove the whole arm anyways, why not replace it all?
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: l400 cv joints
Post by Big-Bird »
It would be nice if there was a supplier other than all the way in BC for some of the common wear parts. Has anyone successfully sourced a partnumber set for CV boots for the L400 where the supply is available anywhere in Canada.
Feels like a monopoly in BC on Delica parts....I'm just saying. 8-)
Feds
Re: l400 cv joints
Post by Feds »
So the Monty cv shafts fit? Thats good news. Rock auto lists both shafts for $40 per. shipping probably doubles that, but... <obama> not bad </obama>
Big-Bird
Re: l400 cv joints
Post by Big-Bird »
Big-Bird wrote:It would be nice if there was a supplier other than all the way in BC for some of the common wear parts. Has anyone successfully sourced a partnumber set for CV boots for the L400 where the supply is available anywhere in Canada.
So i have done some snooping on the USA Napa website and found the following info for the 3.5L equipped Montero relative to CV parts.
CV BOOTS http://m.napaonline.com/Tablet/parts/Pr ... k=Category
CV AXLES http://m.napaonline.com/Tablet/parts/Pr ... k=Category
Can anyone on this forum confirm 100%, total confidence, that the 3.5L Montero CV parts do in fact fit the 2.8L equipped Spacegear. I ask because my local Mitsu Dealer can get OE parts for Monteros, Pajeros and Delis but the part numbers are all different....and they charge 100.00 for a single CV boot which sucks!
Re: l400 cv joints
One thing is 100%
On the L400/Spacegear hub, the inner shaft bearing is different (larger) than the Pajero/Montero/L300.
The outer shaft bearing is the same.
That's why the rotors are different.
Proprietary to the L400. Not sure why they did it that way.
Big-Bird
Re: l400 cv joints
Post by Big-Bird »
Jesse: The CV's outer stub shaft dimensional differences is an interesting point that we all should be made aware of so good timing.
But what about the cv boots? Inners boot numbers I posted are probably okay, outers....not so sure now.
madmazda
Vehicle: 1994 l400
Re: l400 cv joints
Post by madmazda »
So is it possible to buy complete cv joints in Canada or not
Big-Bird
Re: l400 cv joints
Post by Big-Bird »
I would say yes, but that means from the BC or Ont JDM importers who have the supplier source figured out. You could get a pair from a wrecked L400 that RSI or Amazing and rebuild them like I am with the ones I scooped from Pick N Pull last month.
madmazda
Vehicle: 1994 l400
Re: l400 cv joints
Post by madmazda »
THERES ONE IN PICK AND PULL !!!!! 8-) 8-) 8-)
Big-Bird
Re: l400 cv joints
Post by Big-Bird »
Yeah, drive train is already gone and I didn't take it but I know who did and he wants to sell it.
I have the cv axles along with several parts that survived the crash from the rear end collision. Poor L400....such a shame...it might be there still but I haven't been there in 3 weeks. Might have been crushed by now but still worth looking if you need smaller bits and clips.
Return to “L400 Technical”
