My van had some fog lights on it originally, but they have been taken off. The switch by the steering column still has power and
switched power when I turn the lights on. I can't seem to find the switched power lead by the front bumper where the original lights were mounted. Should I just run new wires back to the existing switch? Also I've noticed in my fuse box (by drivers foot) I don't have the #5 (Top-From Left) fuse. There is an inline fuse behind the switch. Some I'm guessing it was just moved there instead. From my understanding the fog lights should only be able to be turned on when the headlights are on, is this correct?
Jeff
Wiring Fog Lights
definingdigital
- Vehicle: Delica
legionnair
- Vehicle: delica L300
Re: Wiring Fog Lights
That is correct also unless they are low amperage led lights you will want to run them off a relay not just the switch.
Dustin
Dustin
definingdigital
- Vehicle: Delica
I'm pretty sure I was told that the factory switch has a relay built in? If this is the case, I could just tap into the feed that has power when it's switched on right?
Don't know what you're driving but I know that with the Starwagon the fogs work fine without the headlamps. When I turn mine on, the running lights ~ that is the red and amber corner lights ~ all come on. The whole idea behind the fog lamps is to work as an alternative to the bright white headlamps for when the fog is thick and the bright white light reflects everywhere. This is how the Starwagon was originally designed and I suspect the same for the Space Gear. The wire feed to the fogs would have originally come from the oil cooler grille (under the bambie bar shroud) and typically use the single wire crimped tubular Denso connector plugs. I think your relay query might be related to the running/marker lights (not the DRLs, which is a modification).
Jay of the TardisDeli would be a good person to get an opinion from as he works with vehicle wiring for a living.
- TardisDeli
Falco is correct in that you don't need the headlights on to turn on the fog lights and there is no control relay for them. The fuse for the the foglights is the fuse you found attached and hiding behind the foglight switch ,thats the factory origanal wa,,,, go figure. Cheers Jay.
Christine
