rear electric curtains
- Breadman
has anyone had any experience with the rear electric sun shades on the exceed model? one of mine doesn't close and one almost closes and the other two work fine. any help would be great.
thanks
paul
thanks
paul
- mark
- Member's Photo Album: http://www.delica.ca/Photos
- Vehicle: 1994 L400
Hi Breadman --My friend in Japan looked into parts cost for replacing the entire mechanism on one side. His general conclusion was that it would be quite costly ($500 to $1000ish for the mechanism for one side).
I looked into the same issue and have a parts diagram for the electric shades on an Exceed. Over the weekend, I'll scan this in.
Mark
Mark
- Breadman
- mark
- mark
- Breadman
- Breadman
i found this link on the uk site i will try some of the fixes this weekend.
http://www.mdocuk.co.uk/forums/viewtopi ... highlight=
paul
paul
- BCDelica
It's such a shame you guys are so far away!
I have a complete working set (all four) of the Crystal Lite roof blinds sat in my garage!
I have some knowledge of how to remove the headlining and roof blind cassettes etc....if you need any info, just leave a message here....
Regards,
Bruce.
Regards,
Bruce.
L300 Mystery Machine (High Altitude Edition
L300 MudMonkey ($400 bargain banger!!
- Breadman
- Vehicle: 91 Exceed
This is where mine runs into problems...
This shows the cable, with a plastic clip end, with the rod through the bottom edge of the blind inserted into the plastic clip, secured by a clip ring.
But on the other side of the blind, the plastic clip end is sheared - blind not connected to cable. I'm building missing pieces of the clip with epoxy and then re-attaching the 2 clip pieces.
Oh, by the way, getting to these blind units was fun: headliners, fluorescent light unit, a/c vent tubes, all out first!
- Vehicle: L300 poptop gasser
