Single -> Dual Piston brake upgrade
Re: Single -> Dual Piston brake upgrade + auto -> Manual hubs
Post by jessef » Thu Sep 04, 2008 9:06 pm
Napa will have them for sure.
You can cross reference the Canada and US Napa part #'s .
Not sure about Lordco but Napa has the 92 Montero Sport brakes
Make sure you get semi-loaded calipers that come with the mounting brackets and pins.
For calipers, you can go any brand.
For rotors, I highly recommend Raybestos PG (professional grade). They cost a bit more but trust me when you see the difference you'll get them.
Pads are personal preference. Don't get the cheap one's. Metallic or Ceramic and a good grade.
The front brakes on these puppies are extremely important compared to mid/rear engine vehicles. :M
Schwa
Vehicle: 1992 Delica Exceed
Post by Schwa » Fri Sep 05, 2008 12:21 am
Is there a difference between the 1989 / 1992 rotor?
Schwa
Post by Schwa » Fri Sep 05, 2008 12:46 pm
Went to NAPA in Coquitlam today and they have nothing in stock, but can get one rotor in today and everything else would be back-ordered, so several weeks, depending on when they put the order through. I'm thinking about making a run for the border, how long did it take to get yours parts Jesse?
Post by jessef » Fri Sep 05, 2008 1:20 pm
Used partsamerica.com
free shipping (ground). took a week. different parts came from different places.
You can get them all shipped to one store in Lynden I think. Shuck's Auto I believe is their store retailer.
Even with taxes, it was a lot cheaper than here.
You'll have to return your cores though. I suggest do the brake job and then take your two cores back to the store. They'll credit you on the spot.
BTW, Raybestos brakes are made here in Canada. Stamped on the rotors. I showed this to the border agent.
Schwa
Post by Schwa » Sat Sep 06, 2008 10:37 pm
partsamerica.com has some loaded calipers in Bellingham but there doesn't seem to be any rotors in any stores they deal with, so it has to be shipped to a US address, which I could do, but I also called NAPA in Blaine and they can get everything in from the Seattle warehouse by Tuesday if I order and pre-pay by Monday... probably go that route since it's closer than the US address I'd have it sent to and likely a bit faster.
A bit ironic that they make the darn things in Canada but are next to impossible to find! I do understand why, but still, it's frustrating. Don't lots of the freshly landed '91+ Pajeros need rotors, or are they really that much better?
Schwa
Post by Schwa » Wed Sep 10, 2008 9:09 pm
Picked up the loaded calipers and rotors today in Blaine... My friend's car got searched going down and coming up, but even though I declared the brake parts they didn't ding me any duty or taxes, so that was nice. Gonna have to grab a few tools at Princess Auto to get the job done, can't even get the auto hub cover off, d'oh!
Post by jessef » Wed Sep 10, 2008 10:09 pm
You are screwing it off, right ? :-D Counter clock-wise
Schwa
Post by Schwa » Wed Sep 10, 2008 10:46 pm
My friend thought he had one of those chain oil filter wrenches, but we couldn't find it and no other tool we tried would unscrew it, so gonna pick one up, also going to need that 8mm hex key, seems the common kits skip this size.
Schwa
Post by Schwa » Fri Sep 12, 2008 10:45 am
Princess Auto didn't have the chain oil filter wrench, but they had the giant vice-grip style which I remember seeing photos of someone using a while ago, and it worked... one side came off fairly easy, the other side needed a little persuasion:
Went with a metric hex impact driver set to get the auto-hub off which worked very well.
I put the wheel back on and lowered it down just enough to stop it from spinning because I had already removed the caliper.
Before the cuts:
After cutting the backing plate:
I didn't do much documenting of the job, mostly because I was just trying to get it finished, which didn't quite happen yesterday, got one side done and new rotor on the hub on the passenger side, still have to cut the backing plate and re-pack the front bearing before re-assembly.
Schwa
Post by Schwa » Sat Sep 13, 2008 2:12 pm
All done! Getting that circlip thing back on was really hard on the driver's side, but it came off much easier than the passenger side.
Had I gone with '89 Montero parts (direct replacements instead of upgrading) it would have been $40 cheaper... not a bad upgrade for $40!
Here's what went wrong with my caliper:
All parts ordered from NAPA in Blaine...
Left Caliper (loaded semi-metalic pads) 442-64009 $70.59
Right Caliper (loaded semi-metalic pads) 442-64010 $70.59
Front Rotor - Premium (x2) 4886687 $49.49 ---> $98.98
Core Deposit on calipers $55 ------> $110
Total $350.16 + $29.41 tax = $379.57
After core returns (hopefully they'll take them) -$119.24 = $260.33 US
Post by jessef » Sun Sep 14, 2008 10:57 am
Nice job :M
Vehicle: 2013 Toyota Tacoma
Post by mararmeisto » Tue Sep 16, 2008 9:35 am
Notice the difference?
Schwa
Post by Schwa » Tue Sep 16, 2008 10:54 am
YES! quite a bit better braking, but I haven't towed the boat yet which will be the real test for them. There's also a slight difference in the way the front end feels, maybe from additional un-sprung weight... hard to say.
Post by jessef » Thu Nov 27, 2008 11:20 am
Had some PM's asking for a difference between Gen I and Gen II stuff.
Brakes
Here you can see the size differences in the hardware. Gen 1 is on top gen 2 on the bottom. The gen 2 pads have much more surface area, but are the same contour of the Gen1.
The splash shield requires some trimming/bending in order to accommodate the bigger brackets.
Before:
After:
Hubs
Gen 2 hubs can be swapped on a Gen 1; there are just a few differences.
Difference #1: the Gen1 has notches which appear to have no function in 3 of the six points where the locking hubs mount. Gen2 on the left, and Gen1 on the right.
The Gen1 hub looks slightly bigger in diameter in that picture but it's an optical illusion; the measured circumference is the same.
Difference #2: the top portion of the hubs have some differences in grooving. On the Gen2 the optional ABS ring would mount in that area. Since the Gen1 wouldn't use the ABS ring, it probably doesn't matter. Gen1 on left, Gen2 on the right.
Note the dimension from the top to the bottom of the hubs are the same.
Difference #3: the Gen2 has a thinner ring where the wheel mounts. Therefore the wheel would be slightly farther in (about 3mm) toward the frame if used on a Gen1. Same picture above.
Rotors
Here's a comparison of the rotors. The distance from the hub mount to the top of the rotors is the same, but the working portion of the Gen2 is obviously thicker, with wider cooling vents in the center. This is the thicker Gen2 3.5L rotor. 27mm as compared to the 22mm Gen1 3.0L rotor.
Also, the hub bolts for the Gen2 3.5L are shorter than the Gen1 (46mm vs. 55mm) The bolts from the Gen1 can't be used to mount the Gen2 3.5 rotor because the threads don't go down far enough for the nut to secure the rotor.
All of the gear I've been using/swapping onto Delica's have been Mitsubishi Montero (North American).
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 » Sat Sep 19, 2009 7:15 pm
Man is this a great post.!!!!!!! I have been concerned about the stopping power as I've recently been on some 10-14 % grades and if I don't go downhill in 1st. it doesn't take long before the brakes start to smell. This looks like a great solution. A little patience with the search can really find some great stuff. Thanks for the great instructions and pictures.
Larry
Return to “Suspension & Brakes”
