Roof rack
nhpenner
Vehicle: Mitsubishi Delica1998 L400
Roof rack
Post by nhpenner » Wed Jan 02, 2019 5:27 pm
Just wondering about what roof racks are best recommended and which fittings to use on a 1998 delica L400 [IMG]https://uploads.tapatalk-cdn.com/201901 ... 3907d9.jpg[/IMG]
Sent from my SM-G965W using Tapatalk
Khrolar
Member's Photo Album: http://www.delica.ca/Photos/VD
Vehicle: 1994 L400, LWB, Super Exceed
Roof rack
Post by Khrolar » Wed Jan 02, 2019 6:01 pm
I believe there's 2 types of roof racks you can get for our delica's.
A basket for the roof that can bolt directly to your vans roof, however this requires drilling holes in the roof to mount it, I don't believe many people go this way
Or the more common option is a gutter mount system.
Thule and Yakima both make gutter mounts for high roof vans. I believe both are around a $300 price tag.
Currently I have the Yakima system mounted to my van, it works well, however I found that the clamps for the feet bend out the gutter on the van, and that the inside of the clamp sits quite close to the metal of the vans roof. To solve any potential scraping I added some 1/8" rubber pads on the back of the clamp.
You will also have to purchase the high roof risers with the gutter clamps to make it compatible with out high roof.
If I was to buy a band new system I would probably go with the thule setup as it looks cleaner.
bitnaut
Vehicle: 1995 Royal Exceed PD6W
Roof rack
Post by bitnaut » Fri Jan 04, 2019 9:31 pm
There’s also rhinorack.ca. I use their RL210 legs and HD Rack. But there’s a fitting guide on the website that includes our Delicas so check into that.
