L300 Manual hubs, Auto lock hubs & Fixed hubs: which are which?
deskinthewoods
Post by deskinthewoods »
So, I'm new to this wonderful world of Delica and the learning curve is steep and surprises abound. I thought I had Auto locking hubs but just found reference to "Fixed" hubs on a post from the UK. I didn't know there were fixed hubs. I know I definitely do not have manual locking hubs but how can I tell if they are Auto locking or fixed? (this search came about as I thought my Auto lock indicator lamp was burnt out as nothing lights up when I'm in 4H or 4L....maybe I just don't have that indicator lamp?)
Auto hubs are easy: they say "Auto Free Hub" on the chromed cover, and are what most Delicas have:
Auto hubs are nice because you don't have to get out of the vehicle to engage them. They're more prone to failure because it's the engine's driving force that engages them- if you select 4WD and floor it, they engage quite violently. Rocking the vehicle to get out of sand or mud (selecting 1st then Reverse repeatedly) causes them to disengage momentarily and then re-engage suddenly, and really hammers them.
Fixed hubs are less common, and usually found on the 4WD vans and long wheelbase wagons, but sometimes on wagon models.
Fixed hubs are the most reliable, because there's no mechanism to break. The downside is that turning the front diff when you're in 2WD creates a lot of drag and extra fuel consumption, as well as wearing out the CV joints and diff faster.
And manual locking hubs are usually aftermarket, and have a centre piece you must turn manually to engage the hubs.
Manual hubs are more reliable than auto hubs because you can only engage them by hand when the vehicle is stationary. They can still break, but it's less common. The downside is that oyu can only engage them by hand when the vehicle is stationary, which can be inconvenient if you're up to your door sills in mud or in traffic on an icy hillside (for example).
deskinthewoods
And it seems mine are "fixed". Thanks again, Growlerbear. Someday I shall fly down and buy you a beer! :-D
deskinthewoods
Can one shift into 4H from 2H on the fly with fixed hubs or do you have to be stopped? Do you have to put in the clutch?
Just to note: you can install any of the 3 styles of hubs fairly easily, they all use the same driveshafts and mounting points. So if you get bored with your fixed hubs it's easy to install manual ones.
deskinthewoods wrote:Can one shift into 4H from 2H on the fly with fixed hubs or do you have to be stopped? Do you have to put in the clutch?
Yes, with fixed hubs you can shift from 2H to 4H and back without stopping and without using the clutch, though mine sometimes shifts easier if I use the clutch.
And for those following along at home: If you have freewheeling hubs, either Auto or Manual, you can also shift from 2H<->4H while moving if your hubs are already locked.
deskinthewoods
Most awesome news. Two beers...
...just remember you shouldn't use 4WD on pavement, only on loose/slippery/irregular surfaces where the wheels can easily slip a little.
The front and rear wheels sometimes need to turn at different speeds (like when cornering) but they can't because they're rigidly linked by the transfer case. Instead, the wheels with the least resistance will slip a little. The transfer case has a big chain inside, and it's the chain that distributes the stress between the front and rear wheels- if you're driving on nice, grippy tarmac and the wheels need to slip, the chain has to handle *way* more force than it's supposed to. Best case it'll wear out faster. Worst case, it'll break. (Though I've never come across a broken one. Usually it's a poorly maintained driveshaft U-joint or CV joint that fails).
deskinthewoods
Thanks for that advice, too...
