PE8W vs PD8W
St1age
Vehicle: Not yet
PE8W vs PD8W
Postby St1age » Thu May 18, 2017 8:24 am
Can someone tell me the difference between a PE8W and a PD8W Spacegear? LWB vs SWB? Engine size?
TRUTHautomotive
Vehicle: Delica L400 High Roof
PE8W vs PD8W
Postby TRUTHautomotive » Thu May 18, 2017 8:49 am
St1age wrote:Can someone tell me the difference between a PE8W and a PD8W Spacegear? LWB vs SWB? Engine size?
PD8W: 2.8D/4WD/normal roof
PE8W: 2.8D (electronic injection)/4WD/high roof
I'm pretty sure they are both SWB but don't quote me on that
TRUTH Automotive Services
izack98
PE8W vs PD8W
Postby izack98 » Fri May 19, 2017 11:49 am
I have a PE8W. It's a SWB.
Not sure about the PD8W
TRUTHautomotive
PE8W vs PD8W
Postby TRUTHautomotive » Fri May 19, 2017 1:25 pm
I have a PD8W and it's a SWB :)
Problem solved!
PE8W vs PD8W
Postby Growlerbearnz » Fri May 19, 2017 3:34 pm
I'm surprised this isn't in the FAQ. (It is now: viewtopic.php?f=16&t=18288)
L400 Space Gear chassis codes.
Example: PD4W HSEGE
First 4 digits (“PD8W”) are chassis, next 5 digits (HSEGE) show options.
1st digit:
P = L400/Space Gear
2nd digit: Wheelbase and drive
A… Standard wheel base - 2WD, high or low roof.
B… Long wheel base - 2WD, high roof
C… Long wheel base - 2WD, high roof, leaf spring
D… Standard wheel base - 4WD, high or low roof on PD4,5,6, Low roof only on PD8
E… Standard wheel base - 4WD, high roof, only XG and higher spec.
F… Long wheel base - 4WD, high roof
3rd digit: Capacity & engine code
3… 2000cc (4G63)
4… 2400cc (4G64)
5… 2500cc (4D56)
6...3000cc (6G72)
8...2800cc (4M40)
4th digit: Style
V… Van (Commercial vehicle)
W…Wagon (Passenger vehicle)
5th and 6th digit: Body shape & doors
HL… High roof, 2 sliding doors
HS… High roof, 1 sliding door
NL… Standard roof, 2 sliding doors
NS… Standard roof, 1 sliding door
7th digit: Transmission
E… 4 Speed Auto (column shift)
N… 4 Speed Auto (floor shift)
Z… 5 Speed Manual (column shift)
8th digit: Features code
D… E
J… G,X
U… GX, XG, Chamonix
G… Exceed 1
H… Exceed 2
X… Super Exceed
P… Royal Exceed
9th digit: Engine specification
blank… Carburettor specification
E… Electronic Fuel Injection
F… Intercooled Turbo
T… Turbo
TRUTHautomotive
PE8W vs PD8W
Postby TRUTHautomotive » Fri May 19, 2017 5:08 pm
Growlerbearnz wrote:I'm surprised this isn't in the FAQ. (It is now: viewtopic.php?f=16&t=18288)
Example: PD4W HSEGE
1st digit:
P = L400/Space Gear
3… 2000cc (4G63)
4… 2400cc (4G64)
5… 2500cc (4D56)
6...3000cc (6G72)
8...2800cc (4M40)
4th digit: Style
D… E
J… G,X
U… GX, XG, Chamonix
G… Exceed 1
H… Exceed 2
X… Super Exceed
P… Royal Exceed
T… Turbo
Can someone sticky this?
PE8W vs PD8W
Postby Growlerbearnz » Fri May 19, 2017 6:27 pm
I've put it in the FAQ and L400 Technical Reference Library (in Shop Manual Downloads), is that good enough?
Who is online
Users browsing this forum: No registered users and 4 guests
