Frozen doors
fozzie
Vehicle: '90 delica exceed
Frozen doors
Post by fozzie »
Merry christmas.Anybody have any tips to prevent doors getting frozen shut. My sliding door is the worst. Sometimes it won't budge even from the inside. Cheers
sub-arctic
Vehicle: L300 Super Exceed
Re: Frozen doors
Post by sub-arctic »
my sliding door is totally frozen right now, cant be bothered to loosen it up. I am going to hose the seal down with IPA (isopropyl alcohol) first to de-ice it so it will open. then I am probably going to use either vaseline or DC-4 on the seals to prevent them from getting iced up when they get cold again,
you can also use winter windshield washer fluid to deice the seals, if you don't have access to a large amount of IPA.
hope this helps! :-D
claude
Vehicle: Delica Exceed jasper
Re: Frozen doors
Post by claude »
i had the same problem. i had to put a fair amount of Vaseline before it help
Leo Tolstoy
Re: Frozen doors
I spray silicon sealant on the door seals. I think it's called CRC? I got it at Lordco. It gets used in aircraft door seals. Fishslapper turned me onto it.
fozzie
Re: Frozen doors
Post by fozzie »
Right on, thanks for the tips everyone!
Golf Cart
Vehicle: 1992 Exceed
Re: Frozen doors
Post by Golf Cart »
You can also massage all your door seals with dialectric grease. The seal will absorb the grease and cause them to plump up. Works good for the side windows that may leak. It an old trick used by the hotrodders.
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: Frozen doors
Post by Big-Bird »
There are a few coin operated carwashes that have blowers/dryers so I always dry my locks, door seals, hinges and the wiper blades to reduce freezeups in winter.
If I do get a frozen door I hit the mall with underground parking and let it thaw out for a few hours.
Silicone spray is best as a preventive measure as it will repel water. I use it on my drysuit zipper when I go ice-diving so I don't get trapped in my suit due to a frozen zipper after the dive.
philmeup1
Vehicle: 1992 Delica
Re: Frozen doors
Post by philmeup1 »
Hey, don't forget about good 'ole PAM non stick cooking spray!! The butter flavour works better as its greasier lol.
Seriously though, I've used it and it does help:) and I'm having the same problem so I decided to go to Key Largo which is where I am now.
See u in the spring
