Page 55 of 59
Posted: Tue Aug 14, 2018 9:33 am
by deskinthewoods
Excellent idea to bypass the power window relay! This has bugged me since I bought Wilson. After figuring it was too much of a contortion act to try to fit a jumper up under the dash, I pulled the relay, opened it up (just unbent the metal indents and it pulls apart) and pulled out the spring, post and that other bit (ie. all the parts that just fall out) and reassembled it without those bits; now it's always a closed circuit.
- IMG_1879.JPG (32.25 KiB) Viewed 22585 times
Posted: Fri Aug 17, 2018 10:45 pm
by Morganizer
I swapped out the aftermarket, clear-lens tail lights that came with it and put in some stock lights, with regular amber turn signals.
Posted: Sat Aug 18, 2018 7:59 pm
by Morganizer
I replaced the clear, aftermarket tail lights that came with the van with stock ones.
- IMG_8884.JPG (438.61 KiB) Viewed 22548 times
- IMG_8892.JPG (391.3 KiB) Viewed 22548 times
Posted: Sat Aug 25, 2018 6:30 pm
by Krazykraut
Finally replaced the old and tired headlights! New lights from eBay, via a Taiwanese company CrazyTheGod that make aftermarket headlights. Shipping was crazy fast. Went with the dark frame, I think it looks pretty cool.
https://www.ebay.com/itm/Delica-L300-99 ... 4084.l1313
They're sold for L300 99-ON but I took the risk, as they looked like they'd fit on my 1993 Exceed. And they do fit perfectly. Came with corner lights. HID with a LED Aura. Easy to install, just have to find a good place to put a bracket for the ballast. Only small issue was the connectors for the corner light did not fit, a small tab was in the wrong place. Easily solved, as the old bulb holder fit into the new lights.
Posted: Sat Aug 25, 2018 6:38 pm
by Khrolar
Does buying the thing count?
1994, LWB, Super Exceed with the crystal light roof, 112k km on the clock.
First off is replacing the stock radio. [img]
https://uploads.tapatalk-cdn.com/201808 ... 775b17.jpg[/img]
Sent from my SM-G930W8 using Tapatalk
Posted: Mon Sep 03, 2018 3:21 pm
by deskinthewoods
Posted: Tue Sep 11, 2018 10:02 pm
by Shaun Van Ramen
replaced the passenger side mirror after breaking it on a parked truck mirror. Got pinched when passing a semi on a side street as he was just starting to move when I was half-way by.
Thanks to Rising Sun for having the part on hand.
Posted: Sat Sep 15, 2018 7:20 pm
by ACKO15
Replaced a leaking exhaust manifold gasket and watched our boost jump from a smoky 5psi up to 10 cruising with the option of opening the relief valve when you floor it.
Posted: Sun Sep 23, 2018 2:43 am
by bitnaut
Finally added my dream roof top tent and awning...an all aluminum Alu-Cab Gen 3 Expedition tent and Rhino Rack Sunseeker awning.
- 929264B1-5EB0-4367-AAE4-DE9A7EAED075.jpeg (605.44 KiB) Viewed 22317 times
Posted: Thu Nov 22, 2018 10:25 pm
by demiro
I replaced the tie rod ends and ball joints.
Posted: Thu Nov 22, 2018 10:29 pm
by Khrolar
demiro wrote:I replaced the tie rod ends and ball joints.
Hey I did that last weekend!
Also got my new roof racks and awning installed tonight.[img]
https://uploads.tapatalk-cdn.com/201811 ... 41c900.jpg[/img][img]
https://uploads.tapatalk-cdn.com/201811 ... 9e238a.jpg[/img]
Sent from my SM-T380 using Tapatalk
Posted: Wed Nov 28, 2018 8:00 pm
by demiro
Rotated my
uniroyal tires and got a wheel alignment from a local mechanic. Tomorrow, I will change the oil and filter.
Posted: Thu Feb 14, 2019 1:18 pm
by KitsuneL400
Put this Uber cool sticker on my ride... well yesterday.
- Kitsune Sticker
- 94FDE742-DCC9-4992-878B-E6B4CEBACC0A.jpeg (136.28 KiB) Viewed 21100 times
Oh, and added a roof tent too.
Aaron
Posted: Sun Apr 07, 2019 9:56 am
by deskinthewoods
After crawling underneath to re-attach the reverse light wires to the switch on the transmission for the third time this winter, I decided to re-engineer the system and installed a switch activated by the gear shift instead. The old wires were corroded back about a foot from the old switch. Ran new ones up high under the body and around the engine compartment to the gear shift. All good now!
Not in reverse
- reverse switch1.jpg (32.29 KiB) Viewed 20683 times
In reverse
- reverse switch2.jpg (31.06 KiB) Viewed 20683 times
Posted: Sun Apr 07, 2019 2:12 pm
by Growlerbearnz
Nice! I thought about doing something similar for the 4WD dash light which is always a bit intermittent, but it makes far more sense for the reverse switch.
