deskinthewoods
Post by deskinthewoods » Sun Jun 09, 2019 2:43 pm
The oil light crapped out on me this week. Flickered on and scared the crap outta me and then went off. I pulled over and checked the oil level: all good. So under the van I went yesterday and reconnected the wire, also the 4WD indicator wire 'cause I was under there anyway. All good :)
I also noticed a puddle in the passenger area after a hard rain a couple weeks ago, after installing the rubber flooring. I guess its always done that but just soaked into the carpet before now. So I tackled the front panel leak issue.
Old caulking
Water leak 1.jpg (29.52 KiB) Viewed 517 times
Scraped off
Water leak 2.jpg (32.63 KiB) Viewed 517 times
Rust cleaned off
Water leak 3.jpg (27.96 KiB) Viewed 517 times
New Butyl sealant
Water leak 4.jpg (28.28 KiB) Viewed 517 times
I used this stuff
Water leak 5.jpg (28.04 KiB) Viewed 517 times
deskinthewoods
Post by deskinthewoods » Mon Jul 01, 2019 7:23 am
After a heavy rain I still have a small leak...windsheild?...wipers?...windshield washer nozzles?...another day...
deskinthewoods
Post by deskinthewoods » Mon Jul 01, 2019 7:27 am
Replaced the boots on the right CV joints...not too difficult actually...
Step 1. Remove dog
Step 2. Take it all apart
Step 3. remove old boots, clean everything really well, re-grease, re-assemble
Sorry for the lack of photos...
Khrolar
Member's Photo Album: http://www.delica.ca/Photos/VD
Vehicle: 1994 L400, LWB, Super Exceed
Post by Khrolar » Mon Jul 01, 2019 1:24 pm
Step 1. Remove dog
Looking good!
Did you remember to reinstall dog after??
deskinthewoods
Post by deskinthewoods » Mon Jul 01, 2019 4:15 pm
Dog seems to be the self-installing type... :-D
DelicaTele
Vehicle: 95 Delica SuperExceed (SpaceGear)
Post by DelicaTele » Mon Jul 15, 2019 6:59 pm
tried a new doctor/mechanic in Edmonton...
E-Town = no-such-thing-as-a-mechanic-unless-you-drive-a-rolling-coal-Ford-Dodge-or-GM-P/U...
...but there's many plug-and-play technicians *rolls eyes* !
deskinthewoods
Post by deskinthewoods » Sun Aug 04, 2019 2:33 pm
I took the week off work to rebuild the Injector pump, do an oil change, install new shocks. Figured it would be a two day job to do the IP but I managed to stretch it out to six. Oil change and shocks a bit later I guess... :-D
deskinthewoods
Post by deskinthewoods » Mon Aug 05, 2019 3:02 pm
Installed new rear shocks today.
Procomp. (I have no idea what the old ones are...whatever they are they were DONE!)
Sexy! (Canadian colours!)
Post by Growlerbearnz » Wed Aug 07, 2019 2:20 pm
An L300 is a Dodge D50 Diesel, it's just put on a bit of weight. ;-)
Vanthony.wa
Vehicle: Mitsubishi delica L300
Post by Vanthony.wa » Tue Aug 13, 2019 9:04 am
ACKO15 wrote:
Sat Sep 15, 2018 7:20 pm
Replaced a leaking exhaust manifold gasket and watched our boost jump from a smoky 5psi up to 10 cruising with the option of opening the relief valve when you floor it.
Hey there! I'm in desperate need of swapping out my exhaust manifold gasket. I have the gasket on hand but wondering if you have any tips on doing it myself. Seems strait forward but ppl have mentioned bolts breaking in the head etc
Ralph in Winnipeg
Vehicle: 94 Strada
Post by Ralph in Winnipeg » Wed Aug 14, 2019 5:39 am
Exhaust manifold bolts breaking is pretty common due to the repeated heating and cooling. You'll want to soak them with penetrant while hot and let cool. I'd recommend being prepared for the worst. Purchase the bolts and nuts, have a drill and taps on hand, bolt extractors (though I generally find they don't work worth a darn) in case you need them. Take your time, you might have to work the nuts back and forth, don't put an impact on them and pound away.
Good luck.
Ralph in Winnipeg
deskinthewoods
Post by deskinthewoods » Wed Aug 14, 2019 6:21 am
Worst case: Helicoil threaded inserts. An actually easy solution to a heart stopping problem. (If your heart does stop, the rest is no longer a problem...)
deskinthewoods
Post by deskinthewoods » Fri Aug 16, 2019 1:10 pm
Got the front shocks on today! (also sexy :-D )
Front Shocks.jpg (41.41 KiB) Viewed 52 times
