deskinthewoods
Post by deskinthewoods »
Excellent idea to bypass the power window relay! This has bugged me since I bought Wilson. After figuring it was too much of a contortion act to try to fit a jumper up under the dash, I pulled the relay, opened it up (just unbent the metal indents and it pulls apart) and pulled out the spring, post and that other bit (ie. all the parts that just fall out) and reassembled it without those bits; now it's always a closed circuit.
Morganizer
Post by Morganizer »
I swapped out the aftermarket, clear-lens tail lights that came with it and put in some stock lights, with regular amber turn signals.
Morganizer
I replaced the clear, aftermarket tail lights that came with the van with stock ones.
Krazykraut
Vehicle: L300 P35W (Apr 1993)
Post by Krazykraut »
Finally replaced the old and tired headlights! New lights from eBay, via a Taiwanese company CrazyTheGod that make aftermarket headlights. Shipping was crazy fast. Went with the dark frame, I think it looks pretty cool.
https://www.ebay.com/itm/Delica-L300-99 ... 4084.l1313
They're sold for L300 99-ON but I took the risk, as they looked like they'd fit on my 1993 Exceed. And they do fit perfectly. Came with corner lights. HID with a LED Aura. Easy to install, just have to find a good place to put a bracket for the ballast. Only small issue was the connectors for the corner light did not fit, a small tab was in the wrong place. Easily solved, as the old bulb holder fit into the new lights.
Khrolar
Member's Photo Album: http://www.delica.ca/Photos/VD
Vehicle: 1994 L400, LWB, Super Exceed
Post by Khrolar »
Does buying the thing count?
1994, LWB, Super Exceed with the crystal light roof, 112k km on the clock.
First off is replacing the stock radio. [img]https://uploads.tapatalk-cdn.com/201808 ... 775b17.jpg[/img]
Sent from my SM-G930W8 using Tapatalk
deskinthewoods
New Boost and EGT gauges arrived. Made some mounting thingies out of 2" ABS plumbing bits :-D
Gauges 2.jpg (61.67 KiB) Viewed 14322 times
Gauges 1.jpg (71.59 KiB) Viewed 14322 times
Shaun Van Ramen
Vehicle: '91 Exceed
Post by Shaun Van Ramen »
replaced the passenger side mirror after breaking it on a parked truck mirror. Got pinched when passing a semi on a side street as he was just starting to move when I was half-way by.
Thanks to Rising Sun for having the part on hand.
BAHahahahahahaha
ACKO15
Vehicle: 1991 Delica L300
Post by ACKO15 »
Replaced a leaking exhaust manifold gasket and watched our boost jump from a smoky 5psi up to 10 cruising with the option of opening the relief valve when you floor it.
bitnaut
Vehicle: 1995 Royal Exceed PD6W
Post by bitnaut »
Finally added my dream roof top tent and awning...an all aluminum Alu-Cab Gen 3 Expedition tent and Rhino Rack Sunseeker awning.
demiro
Vehicle: Delica
Post by demiro »
I replaced the tie rod ends and ball joints.
Khrolar
Post by Khrolar »
demiro wrote:I replaced the tie rod ends and ball joints.
Hey I did that last weekend!
Also got my new roof racks and awning installed tonight.[img]https://uploads.tapatalk-cdn.com/201811 ... 41c900.jpg[/img][img]https://uploads.tapatalk-cdn.com/201811 ... 9e238a.jpg[/img]
Sent from my SM-T380 using Tapatalk
demiro
Vehicle: Delica
Post by demiro »
Rotated my uniroyal tires and got a wheel alignment from a local mechanic. Tomorrow, I will change the oil and filter.
KitsuneL400
Vehicle: 1999 Space Gear
Post by KitsuneL400 »
Put this Uber cool sticker on my ride... well yesterday.
Kitsune Sticker
Kitsune Sticker
Oh, and added a roof tent too.
Aaron
deskinthewoods
After crawling underneath to re-attach the reverse light wires to the switch on the transmission for the third time this winter, I decided to re-engineer the system and installed a switch activated by the gear shift instead. The old wires were corroded back about a foot from the old switch. Ran new ones up high under the body and around the engine compartment to the gear shift. All good now! :-D
Not in reverse
reverse switch1.jpg (32.29 KiB) Viewed 12548 times
In reverse
reverse switch2.jpg (31.06 KiB) Viewed 12548 times
Nice! I thought about doing something similar for the 4WD dash light which is always a bit intermittent, but it makes far more sense for the reverse switch.
