- Vehicle: l400
I finally tackled my rattling tailgate. Ever since i got the van it sounded like a bunch of gravel was rattling in the bottom of it. Turns out its the glue that holds the inner structure to the outer shell let go. After cleaning it as good as possible I glued everything back in place using construction glue. I tried different kinds to experiment. I ended up using two kinds of LePage construction adhesive. Time will tell if this works. The pictures are not that good but some of you will know what i am talking about.
My tailgate now sounds much more solid when I close it.[img]https://uploads.tapatalk-cdn.com/201709 ... f7d220.jpg[/img][img]https://uploads.tapatalk-cdn.com/201709 ... f5f21e.jpg[/img][img]https://uploads.tapatalk-cdn.com/201709 ... ab11c0.jpg[/img][img]https://uploads.tapatalk-cdn.com/201709 ... 549f6a.jpg[/img]
- Vehicle: Mitsubishi Delica
204explorer wrote:I finally tackled my rattling tailgate. Ever since i got the van it sounded like a bunch of gravel was rattling in the bottom of it. Turns out its the glue that holds the inner structure to the outer shell let go. After cleaning it as good as possible I glued everything back in place using construction glue. I tried different kinds to experiment. I ended up using two kinds of LePage construction adhesive. Time will tell if this works. The pictures are not that good but some of you will know what i am talking about.
It may be coincidence, or maybe every l400 tailgate comes apart, but I literally just picked up PL construction adhesive for the exact same reason as yourself. As in I just purchased it 1 hour before I read your post. I always have been annoyed by the shitty sound coming from there while on a bumpy road, and when closing the gate. So while I was messing around with some wiring and upgrading to LED bulbs my goal was to also do some soundproofing behind the interior panel of the tailgate. This is when I noticed the separation between the panels. Some wires are wrapped in a bit of foam for sound protection and some are not. My plan is to use some 1/4 inch foam weatherstripping I have lying around from walmart to wrap around wires etc. The rear window wiper motor is another culprit of shit noise. Before I'm done I will let allow some very trusted individual with more driving experience than myself, drive down a shit road with me in the back to identify all the sources of shit noise.
- Vehicle: l400
It seems to me you also need a bettet radio and speakers to drown out all the rattling coming from the back. It works for me[emoji6]Hitomi wrote:204explorer wrote:I finally tackled my rattling tailgate. Ever since i got the van it sounded like a bunch of gravel was rattling in the bottom of it. Turns out its the glue that holds the inner structure to the outer shell let go. After cleaning it as good as possible I glued everything back in place using construction glue. I tried different kinds to experiment. I ended up using two kinds of LePage construction adhesive. Time will tell if this works. The pictures are not that good but some of you will know what i am talking about.
- bitnaut
- Vehicle: 1995 Royal Exceed PD6W
Finally got my roof rack and basket for my solar panel on the ol’ L400 Royal Exceed
- feetforbrains
- Vehicle: 1991 Delica L300 Chamonix
Fabricated two liscense plate adapters. Mounted plates. Looking fine
Sent from my Nexus 6P using Tapatalk
- Vehicle: l400
I permanently installed a 3.5 amp battery charger in my engine bay. This way if i feel like my batteries need a top up or warming up during a cold manitoba winter night i dont have to fumble with stiff charger cables, I just plug in a extension cord.
My espar heater draws some juice plus long glow plug cycles plus short trips in the winter are hard on the batteries. The batteries are Delco, probably not the ones I would have chosen for this climate.[img]https://uploads.tapatalk-cdn.com/201710 ... db3db2.jpg[/img]
Last week I was trying ( and still am ) to find the source of a current drain on my battery. I removed the panel from the rear door to check the latch and while there found out my van IS equipped with the bulbs to light up “Delica“ on the rear door. I searched through the L300 section of tech stuff and in general followed Profister's lead. (viewtopic.php?f=98&t=2143 ) I did upgrade to LED's equivalent to 20W incandescent which should be much brighter than the 8W units he used. Very impressed with the results. Only problem may be the LED's I used are for indoor use which I only found out when I went to install them.
- Size and packaging for LED
- 100_8341a.JPG (311.14 KiB) Viewed 11850 times
- Old bulb and new LED
- 100_8342a.JPG (330.33 KiB) Viewed 11850 times
- DELICA all lit up
- 100_8344a.JPG (335.43 KiB) Viewed 11850 times
- Vehicle: L400
2" lift kit installed today! Alignment is next. Rancho RS9000 series shocks on the way for all four corners.
I'm looking at these rims:
Pro Comp Rock Crawler Series 97, 15x8 Wheel with 6 on 5.5 Bolt Pattern - Black 97-5884
with Duratrac's 31x10.5x15
and these fender flares:
Pacer Performance 52-192 Flexy Flares Black 1-3/4" x 58" Heavy Duty Reinforced Rubber Fender Extension Kit - 4 Piece
https://www.amazon.ca/gp/product/B00029 ... YIK6Y9EEQB
Any advice is greatly appreciated!
- bitnaut
Installed new JAOS bullbar with CIBIE fog lights and 14” BrightSource lightbar
- 0C815893-7319-473B-B038-713A749E0E0B.jpeg (764 KiB) Viewed 11558 times
- E4754AD3-77D7-4AB8-928B-2785E44637CB.jpeg (357.62 KiB) Viewed 11725 times
- deskinthewoods
- Vehicle: 1991 L300 Star Wagon named "Wilson"
Tried to get it safetied on Monday but figured it wouldn't pass as Quebec safeties are notoriously tough, and it didn't. So over the last few days I have pulled off a rear leaf spring to have one broken leak replaced and reinstalled it , adjusted the rear brakes where the left side adjuster was seized but I took it apart and got it adjusting again , installed a new muffler, installed a rear top middle brake light, installed rear mud flaps, added reflectors front and rear sides, cleaned the front headlights (as in, took them apart and cleaned the inside as they were full of dust - actually thought one was burnt out but it was just really dirty!), replaced every burnt out bulb I could find, reattached the front filler panels using zip-ties and, tomorrow I will adjust the front left bearing...oh, and there is a sticker on the driver's door that says the tire size is 215 SR15 so I had to do a quick KIJIJI purchase of used tires ($40) as the 235/75R15 I JUST PURCHASED are "TOO big for the vehicle, monsieu".
Getting them swapped on Wednesday. Then, off to get it re-safetied and registered and plated. Then get the tires swapped back!!!
Any advice is greatly appreciated![/quote]
Hi Manitoba
The flexy flares work okay, may wrinkle a tiny bit in the flat top front fender wheels on the series 2 Deli. Not too many other solutions and certainly the price is good.
Try maching out a set of toyota mags. The centers need maching out but a much better idea than black steel rims. The offset is greater as well. I found a set cheap on craigslist. Talk to your tire shop about the rims, mine told me which ones to buy.
have fun
Hi Manitoba
have fun
- deskinthewoods
And now it is safetied and registered and on the road...
- deskinthewoods
I was at the pumps the other morning, no coffee in yet, had the gasoline pump nozzle in my hand...."WTF!!!"...took some affirmative action...
Also, so I can not be in a zero caffeine state at the pumps again, cup holders!
Ans, for good karma generally...Buddy
- Growlerbearnz
- Vehicle: Delica P25W
"I think the left front wheel locks up first" quickly got out of hand. Stripping and rebuilding the callipers, fitting thicker discs (from a Pajero or Pajero Sport), and a set of thoroughly mental Pagid RS5 brake pads because the race brake guy loves Delicas too.
I'm not sure the van will survive being pushed off a cliff 15 times, but we'll see.
And tomorrow, I get to bed the pads in! From the Pagid break-in procedure: "10 stops with low pressure from 150kph down to approximately 80kph, followed by a sequence of 5 stops with medium to high pressure from 180kph to approximately 60kph..." I'm not sure the van will survive being pushed off a cliff 15 times, but we'll see.
- deskinthewoods
Today, a rainy day...
I performed the EGR removal operation.
Now you see it...
now you don't...
I used some 3/8" steel I had on hand (overkill) for the blanking plates and installed an EGT probe while I was in there.
Hoping to get the EGT gauge installed later this weekend, maybe a Turbo Boost gauge, too...
[adden-dumb: got in to test drive Wilson and discovered I'd buried the seat belt buckle under the seat when I reinstalled it ]
Now you see it...
now you don't...
Last edited by deskinthewoods on Sat Jun 23, 2018 2:54 pm, edited 1 time in total.
