Hub install - Saskatoon
Firesong
Post by Firesong »
If anyone is in the neighborhood and wants to install their hubs
at the same time, Im going to do mine probably around 2 pmish.
I have the garage and tools, should be fun.
Saturday (today) 8/28/10
Firesong
Firesong
Re: Hub install - Saskatoon
Post by Firesong »
I went ahead and had a look at mine, figured what the heck.
Total job time was under an hour easy.
Hardest part was putting that darn C clip back in the groove :)
Looks good.
It's easy.
Don't be intimidated by this job, you can do it in the driveway easy.
To take the outer ring off (cap of auto) I used big pipe wrench.
J
after oil
Post by after oil »
thanks for the heads up. my hubs are waiting at the bus depot. happy to know it went easy. id like to see some photos if somebody else does this
Vehicle: -
Post by fexlboi »
I highly recommend the right pliers for the clip. It is just so much easier and saves you quite bit of time and swearing :-D
Firesong
Post by Firesong »
I ended up simply using two flat blade screwdrivers.
It came off easy, putting it back on took a little more time.
It's certainly doable with out the right pliers, just takes
a bit of calm :)
FS
Return to “Events - Saskabush”
