L400 Part Numbers
Posted: Sat Mar 27, 2010 2:03 am
by fexlboi
Just in case you try to find l400 part numbers. This website is a great place to find them.
http://www.japancars.ru/cat/mitsubishi/ ... A8A6A&mdl=
L400 OEM part numbers
Posted: Wed Jul 21, 2010 2:00 pm
by Mark_R
Hope these are of use to someone, OEM part numbers for most common L400 parts
PLEASE USE THIS FOR REFERENCE ONLY, ALWAYS CHECK PART NUMBERS WITH YOUR DEALER QUOTING YOUR CHASSIS NUMBER:
MB270012 - Bonnet stay clip
MB326019 - Instrument nut
MB476821 - Front grill clips
MB584750 - Bolt hub
MB618227 - Front caliper slider bolt upper
MB618228 - Sliding caliper bolt, lower, Front one each side
MB619578 - Diamond badge set
MB624908 - Front disc wheel holder
MB687002 - GASKET FOR EXHAUST
MB699584 – CALIPER SLIDER BOLT Rear top
MB699585 – CALIPER SLIDER BOLT Rear bottom
MB837108 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L
MB837110 - AT TRANSMISSION BOX SWITCH, T/F G/SHF H-L LAMP
MB857612 – rear caliper Seal kit for above
MB857613 – single piston rear wheel
MB857837 – single piston front wheel
MB857840 - Seal kit front brake caliper
MB858394 – caliper carrier Front Right
MB858395 – caliper carrier Front Left
MB877848 - Light lens for sliding door step lamp
MB882036 - Black clips and rubber covers to lock back windows
MB886676 - Boot kit f/axle
MB896029 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L
MB922064 - Dust cover Track rod end
MB924891 - L400 header tank
MB927593 - Left Hand Sliding Door Handle
MB927686 - Nylon Roller for sliding door
MB942997 - Original key fob for alarm
MB951788 - Steering joint shaft
MB952637 - N/s mirror to door trim
MB954865 - Remote locking key fob transceiver, Type G8D-280M-B17
MB957431 - exhaust rear section SWB
MB957433 - Rear Exhaust for LWB
MC840219 - Oil pressure switch
MC994292 - Universal joint kit
MD020233 - Head bolt washer 4m40 head
MD050317 – sump plug washer
MD180581 - Power steering belt
MD313660 – fan belts x2
MD337888 - Glow control relay
MD620874 - Throttle position sensor (not on mitsu parts system)
MD727105 - Gauge water temp (dash panel)
MD951857 - part number for sump bolt
MD951858 - sump bolt washer
MD970389 - Liquid gasket (engine)
ME088532 - Oil filter
ME190013 - Chain tension guide
ME190016 - Chain tension guide (fixed)
ME190016 - Timing chain guide
ME200244 - Timing chain
ME200248 - Timing chain tensioner
ME200414 - O-ring (water pump to chain cover)
ME200491 – crank shaft pulley bolt
ME200970 - Glow plugs
ME201328 - Pipe(thermo housing to cylinder head)
ME201700 - Diesel pump
ME201998 – Diesel pump
ME202443 - Glow plug bus bar
MF240055 - Sump guard bolts
MF660066 - Front axle sump plug washer
MH014054 – Alternator belts x2
MH035529 - O-ring (thermostat housing chain cover)
MR105741 - battery tray
MR110859 - Repair kit boot ball joint
MR111098 - Speed sensor drive cog
MR112385 - Rear Shock L400
MR112710 - Lower wishbone bush (front of front wishbone)
MR112711 - Lower wishbone bush (rear of front wishbone)
MR115680 - Joint RR Heater Pipe
MR122305 - Speed sensor (gearbox)
MR126103 - Radiator
MR129007 - Handbrake cover
MR149203 - Hazard light switch
MR151285 - 31mm front anti roll bar bushes
MR151971 - Track rod/tie rod
MR151976 - Steering gator kit
MR161679 - timing chain guide
MR166198 - sensor A/T speed
MR167676 - main dash clock cover
MR167722 - Bulb dash illumination
MR167724 - Bulb instrument panel (warning lights)
MR167725 - "D" light bulb
MR175427 - L400 air conditioning receiver dryer
MR175492 - Compass bulb
MR192015 - wiper assembly
MR192417 - Indicator/sidelight unit left
MR192418 - Indicator/sidelight unit right
MR192449 - Rear nozzle for wash/wipe.
MR195468 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L
MR195470 - AT TRANSMISSION BOX SWITCH, T/F GEARSHIFT 4WD L
MR196836 - Front prop shaft universal joint
MR204842 - Element air cleaner
MR234642 - Sump guard
MR267370 - Auto gear selector
MR267538 - Shock Absorber Rear (ECS type)
MR267684 - Rear anti roll bar bushes
MR281671 - top hose to radiator
MR298583 - hand grip roof inside
MR353425 - Shock Absorber Front (ECS type) L400
MR360148 - A/con belt
MR416912 - Headlight washer pump
MR502584 - Original keyfob transmitter case ??
MR502590 - Original keyfob transmitter case ??
MR712796 - end cap that fits on hand grab rail by sliding door
MR720570 - Centre console
MR720572 - Cup holder (front)
MR727105 - Centre console heater/radio control
MR727138 - Roof gutter 2 piece
MR727150 - Roof gutter 2 piece
MR727168 - Guttering trim moulding clip
MS450044 - Spring Washer to fit Shock absorber lower mount
MU100015 - Bolt, to fit shock absorber lower mount
MU840022 - 100 a fuse
XB511003 - Front brake pads
XB220900 - Fuel filter
XD310484 - Balance belt (4d56 only)
MR112219 - CLUTCH MASTER CYLINDER - PEW8 versions.
Re: L400 Part Numbers
Posted: Wed Jan 26, 2011 3:09 am
by Asm
Re: L400 Part Numbers and the best parts prices
Posted: Wed May 18, 2016 8:55 am
by thelazygreenfox
Search out the part number/price on Megazip or Amayama or japan cars. If this appears overwhelming order from RMI, CCA, Rising Sun, Amazing auto or the other local dealers.
http://www.megazip.net/zapchasti-dlya-a ... ue9-625031
https://www.amayama.com/en/
http://www.japancars.ru/cat/mitsubishi/ ... A8A6A&mdl=[/quote]
Google the part number and search all the parts locations (ebay, amazon, febest, mega, amayama etc)
Try febest online for mainly rubber parts. Their prices are the best I've found. Match up the Mitsu part number with the febest number and
visually ensure it's the correct part before ordering.
http://febestparts.com/catalog/MITSUBIS ... _1994-2004
I'm ordering a brake rebuild kit and rear transmission mounts from them, much cheaper
than either Amayama and megazip, not sure about shipping costs.
good luck
MD
Posted: Wed May 18, 2016 9:58 am
by thelazygreenfox
This is my Febest order with a Megazip price comparison beside. All prices American.
Items in order: 5
Order price, $: 156.26
Code Amount Price $ Total, $ Name Delete
0475-V45F
2
10.95 ($A44 megazip) 21.90 CYLINDER KIT (Front brake cyl rebuild)
MM-PD8R
2
24.58 ($A90. megazip) 49.16 REAR ENGINE MOUNT (transmission mounts)
0423-PD8WF
2
17.36 ($A75 megazip) 34.72 FRONT STABILIZER LINK / SWAY BAR LINK
0423-PD8WR
2
14.29 ($A51 magazip) 28.58 REAR STABILIZER LINK
0475-PD5R
2
10.95 ($A14 megazip) 21.90 CYLINDER KIT(Rear brake cyl rebuild)
Gotta love cheaper prices.
Megazip is often the lo cost supplier but as you see above Febest is cheaper. These are L400 parts but try for L300 parts too.
MD
Re:Delica parts, cheapest price and shipping
Posted: Thu May 19, 2016 4:48 pm
by thelazygreenfox
Turns out the easy way to buy from Febest is to log on to Ebay and type in the part number you need. If Febest has it in stock their ad comes up and you buy it then.
Febest ships free to any american address. If you ship to Canada you pay American and Canadian postage and
often duty, PST, and GST.
Good luck
MD
