Front Wheels Bearings
sfd_656
Vehicle: l400
Post by sfd_656 »
Ive got some play in the front passenger side wheel bearing. I need to find some new bearings going to do both sides. Does anybody know if montero parts are interchangeable? or any easy access part numbers?
You can look up the Mitsubishi part numbers by putting your frame number into https://mitsubishi.epc-data.com/delica_space_gear/
Once you know the part numbers, throw them into Google, you'll often find equivalent/interchangeable parts. Try putting the part number into Amayama.com; they supply genuine Mitsubishi parts, but they'll often also suggest a generic (direct from the bearing manufacturer) equivalent. You can then use the generic bearing part number to order from somewhere more local. (Or order from Amayama.com if you have time to wait for shipping, their prices are pretty good.)
