Hi! Looking to buy a 2002 V6 Space Gear and the shop I took it to for an inspection found a small engine oil leak (not dripping on the ground). The leak can be seen when laying down behind the driver-side wheel.
Hoping someone can help me shed some light on where this leak could be coming from. I talked to a few mechanics and they said it's most likely the valve cover gasket but said they couldn't be sure until they looked into it further, which is making me a little nervous. Seems to me the valve cover is nowhere near the leak. Could it be another gasket?
Any help is much appreciated!
Engine oil leak
- Vehicle: Delica Space Gear
Engine oil leak
- Oil leak
- r_5efa18e1-8cf3-4585-80e5-98253f6083aa.jpg (163.81 KiB) Viewed 3168 times
- MardyDelica
Engine oil leak
valve cover gasket is gone.
best way to change spark plug also , & complete ignition wire
Engine oil leak
Thanks for your help Mardy. I ended up buying another Delica (I may have to take a trip to come see you for some maintenance and repairs soon, i'll send you an email)
