headlights
Bcorcoran
Vehicle: 96 l400
headlights
Post by Bcorcoran »
96 delica 1 gen. both high and low beam bulbs are H1. The low beam (outter bulb) has 2 small wires fed into headlight lense. Also behind the projection lense is a small black mechanism which wires is attached to. Can someone tell me what this is for and how to remove it or can I cut the wires and put in the proper H1 and H4 bulbs?
tks
headlights
Could it be a Daytime Running Light (2 wires going to a small bulb in the headlamp), or a Xenon/HID conversion?
Any chance of a photo? (must be smaller than 900 pixels wide to upload here using the "attachment" option).
Bcorcoran
Vehicle: 96 l400
headlights
Post by Bcorcoran »
Growlerbearnz wrote:Could it be a Daytime Running Light (2 wires going to a small bulb in the headlamp), or a Xenon/HID conversion?
no its not a daytime running light I don't think anyway. when I purchased it from velocity it had the head light relay removed and a jumper wire there so the lights come on with key!! Prob a xenon conversion. I will get a pic tomorrow its currently in storage.
thank you
bill
Bcorcoran
Vehicle: 96 l400
headlights
Post by Bcorcoran »
sorry i never got back with pics. problem solved...its a projector lense installed b4 i purchased the vehicle. i removed the lense and took it out, then installed a led H4 bulb , works great
thanks for your time
Return to “L400 Technical”
