SRS Light on after stereo/DRL install
saltypeanuts
Vehicle: L400 Series 2
Post by saltypeanuts » Mon Mar 12, 2018 9:36 pm
I removed panels from the dash to clean up wiring from the Japanese owner and add a radio/DRL module. Everything was working great, until the SRS light started coming on the day after. Is it possible I may have bumped a connector or reset the system by disconnecting the battery?
What I've tried so far: checked/wiggled all connectors I could find for the SRS system. Checked all fuses in the under-dash and engine boxes. Disconnected any wiring I added (stereo harness).
Any suggestions on how to proceed? Any Calgary locals with a scan tool or know of a shop that can check for me?
Thanks!
kurtiswilk
Vehicle: 97 L400 super exceed
Post by kurtiswilk » Wed Mar 28, 2018 10:43 pm
Every have any luck with this?
I have an srs and park brake light on super faint.
although im pretty sure mines to do with turning it on without a sensor plugged in to turn the wheel well replacing a cv boot.....
I've just lived with it for the past while cant seem to find a fault anywhere
Deli Duncan
97 L400 gen 2
saltypeanuts
Post by saltypeanuts » Mon Apr 02, 2018 3:10 pm
No luck so far. Had a shop try with a couple different tools and techniques.
I'm going to buy an Evoscan cable and see what I can find - it's not explicitly designed for Delicas but some people apparently make it work. I'll shoot you a PM once I get it, you can try it out if you'd like.
kurtiswilk
Post by kurtiswilk » Tue Apr 03, 2018 9:20 pm
Sounds like i plan. I'm also a Calgary local so if you ever need a hand Turning a wrench let me know.
Deli Duncan
97 L400 gen 2
