L400 2.8 stalls in cold 2 min after starting fine.
Posted: Mon Feb 06, 2017 11:21 am
Hi there,
Temp drop here in Vancouver again has caused my l400 to rear it's cold start issues again. Will turn over and idle perfectly in the cold but after what seems to be around 2 mins it will start to struggle and stall (every time it's around 0 degrees or below). If i start driving right away sometimes i can keep a steady foot on the gas and it comes good but if I'm parked and do not apply gas it will stall every time. After it does stall, it's usually more difficult to get it to start but once it does it's completely fine. It will not stall again.
I've had glow plugs, bus bar, battery and such all checked by CVI and all are in normal working parameters.
1995 S1 2.8 SWB PE8W
Anyone else had this kind of problem?
Cheers good people!
Cheers good people!
