heaters blowing air but not hot. middle vents only
shaner
Vehicle: L300
Post by shaner »
Hi guys
Here is an odd one.
The vents closest to the console do not blow warm air when the temp is turned up, the vents closer to the window do.
Is there a separate control for these vents?
no over heating issues and coolant level is remaining stable
cheers
Shane
Daddiohh
Vehicle: 1995 L400 Exceed 2 High Roof
Post by Daddiohh »
Mine is the same, I think they are only fresh air. I use the outer 2 to assist with side window defrosting.
Sent from my iPad using Tapatalk
