Rear u joint part number
As the title says, rear u joint part number?
Re: Rear u joint part number
MR232151 according to http://www.partsbase.org/mitsubishi/del ... shaft-p-2/
thank you much, I wasn't aware of this site
okay so the MR number is one thing, then there is 31829. neither are bringing anything up at napa. Any way to cross reference?
Google is your friend (apart from that privacy thing).
Putting the MR232151 number into Google brings up a bunch of results for me, including one at Amazon (you could buy the part there if you have to) which cross-references a bunch of other part numbers. Try one of these: MC994292, MR232151, ASHUKI - 08760005; FI. DI. - GUM93; HERTH+BUSS JAKOPARTS - J2925000; JAPANPARTS - 6605502; KAISHIN - GUM93; MITSUBISHI - MB293425; MITSUBISHI - MB837951, 6605502, D156002, JO502, MB293425, MB837951, MC834855, MC994292, ASM-93
Of course, this advice is from the Internet via a guy you don't know who lives on the other side of the planet, so use at your own risk
Oh, regarding the way parts catalogues work: The 31829 is an illustration identifier only used in the parts catalogue. To find the real-world part number you need to use the cross-reference table. It's a bit counter-intuitive (why use one part number to look up another part number?) but manufacturers do this so that they don't have to change the drawings every time they change a part number, and so they can use the same generic drawings for multiple models of vehicle which might actually use different parts.
