Possible Tranny Trouble - Shifting Issues
CREGAN
Re: Possible Tranny Trouble - Shifting Issues
Post by CREGAN »
MardyDelica wrote:hi, craig, you need a tps sensor.
if its in this case.
check again if you do it right sometime we did hock up in the wrong wire and then there is no reading .
check again pls.
do it slow step by step pls
Cheers;
Hey Mardy - I have done it four times now since last night and still the same result. I never unhooked any wires or anything other than the 2 to the intercooler. I will check it one more time.
Craig
MardyDelica
Post by MardyDelica »
hi, craig,
ok pls phone me
thank you
Profister
Post by Profister »
mrdueck wrote:My TPS is turned to the max. It goes OK but the voltage is almost 1. Profister, how much is a new TPS?
Sorry for the delay; I was away camping. I am not sure about the cost because that was a part of pre-sales service at Amazing Auto Imports and Mardy mentioned my name already. According to Google the part MD620874 price is bouncing at around $200.
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
1st generation Dodge trucks with the 12V Cummins have a problem TPS as well....The solution on the Dodges is to wire in a volume control on the dash. You can set the resistance and gives you nice on the fly adjustment of the shift points.
We did this on a friends Cummins and it works awesome...total cost is 12.00 and maybe a good solution.
Just an idea $12.00 is better then $200.00 and I cannot tell you how nice the adjustable shift points are towing, driving, hills etc..
Here is the link:
http://www.dieseltruckresource.com/dev/ ... l?t=142641
oceanchem
Vehicle: Mitsubishi L400 Spacegear 1996
Post by oceanchem »
I know this is way down thread but this information saved me as well. Was told I needed a transmission inspection and likely rebuild. Found this, moved my intercooler out of the way and then found the voltage on my TPS to be 0.62 V. Adjusted to 0.8 V and my problems disappeared for now. Thank you.
oceanchem wrote:I know this is way down thread but this information saved me as well.
This thread is a great find! I've made a copy to the L400 Technical Reference Library (minus the off-topic posts), hopefully others with the same issues won't have to search quite as hard as you did. Thanks!
runner5754
Vehicle: 2002 Delica Space Gear
Post by runner5754 »
I’m having similar transmission issues but my delica is a 2002 model so not sure if it even has a TPS. Any ideas?
oceanchem
Post by oceanchem »
A year and half later and everything is still just fine. This information saved my vehicle and saved me from selling it for a huge loss more than likely.
