"Auto" option - headlights.
- Vehicle: L400
Does the option triggers a sensor so the head lights shut off at a day time?
- Vehicle: L400
Re: "Auto" option - headlights.
You guys don't have this option?
- Mr. Flibble
There should be a little square sensor on top of your dash, in the right corner in front of the driver. It may be covered with something in your case or perhaps not working?del_man wrote:Does the option triggers a sensor so the head lights shut off at a day time?
As long as your light switch is set to "Auto" it should adjust your lights based on how much light the sensor sees.
