Fuel Injector Install
WestCoastr
Vehicle: 92 L300
Post by WestCoastr » Sun Feb 03, 2019 3:35 pm
Hi,
Just prepping a new head for install..
I have purchased the copper washers (base seals) that sit in the injector ports, the return seals that mount on the top of the injector before the fuel rail, and the injector tip heat shields. However, I'm not sure where these heat shields go. Is it possible that my injectors didn't have these initially? Any input would help. Here is a link to the part. It has a rounded side and a flat side.
http://www.ccautos.ca/fuel-injector-tip-heat-shield/
Post by Growlerbearnz » Mon Feb 04, 2019 1:28 pm
The base seals go in first, they sit between the head and the very tip of the injector (surrounding the injector needle/pintle). The old ones might still be in the head- they get gunked up with soot. You'll want to scratch around in there with something pointy to see if you can find them.
When you're installing the new ones, the rounded side goes down- towards the head, the flat side goes towards the injector.
WestCoastr
Vehicle: 92 L300
Post by WestCoastr » Mon Feb 04, 2019 10:41 pm
Thanks! Makes perfect sense. Appreciated as always.
