I just posted this to my native forum, I hope it can be of help to you guys too!
http://www.mdocuk.co.uk/forums/viewtopic.php?t=49512
Dave
Complete Engine Oil Leak Guide for the L300 (4D56T)
- Vehicle: L300 Exceed (White)
Nicely done! Mind if I copy-paste it into the reference library here? Just in case MDOC goes down?
...though you missed one trick. MD372348: Alloy Half-moon seal, replaces the rubber half-moon seal under the rocker cover. Use grey silicone (the stiffer, high-strength stuff, as used on the sump) when fitting the alloy halfmoon. Your rocker cover will never leak again.
Be my guest. :)Growlerbearnz wrote:Nicely done! Mind if I copy-paste it into the reference library here? Just in case MDOC goes down?
Never knew such a thing existed! Should mine go again that will be getting whacked in there, cheers!
Dave
