Alternator mount wear...
- ChuckBlack
- Vehicle: L300 Jasper
Has anyone experienced their alternator mounting bolt slightly bending? I've come to the conclusion that my long time squeeling belts are now due for a quick you know what!!!
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
I've not yet seen a bent lower bolt, but I've seen lots of lower mount brackets with flogged out holes. Could that be the reason the bolt is bent?
My solution to the flogged out hole was to drill it and the alternator lugs out to 10mm and use a larger bolt. It's tricky to get a drill in there, but if you remove the radiator you can get a straight shot.
- ChuckBlack
have you done it?
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
Yup, on my old engine.
- ChuckBlack
did it last?
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
LOL it outlasted the engine, at least! There's heaps of meat in the alternator bracket and lugs, and going from 8mm to 10mm only takes a millimetre out of it.
Easier than replacing the alternator bracket, since that's part of the oil pump.
- Vehicle: L300
had same issue with mine. Pulled the front cover and welded the hole closed. Then drilled it out on the drill press.
- ChuckBlack
Sounds like you have too much time on your hands!!! A new piece cost around $350
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
- Vehicle: L300
built not bought? Lol
- ChuckBlack
Alright.
Here's what I did. Drained the coolant and removed the rad,
moved the power steeling pump aside,
removed the fan,
disconnected the batteries,
dismounted the alternator but I didn't removed the back oil tube or the electrical connections.
Moved the alt enough to have enough space for my tap.
I made 3/8 tap then used a 3/8X4.5 inch ready rod ending with a nylock on either end.
Holy that worked great. All straight up.. Better than OEM...
Took me 6 Hours
I no longer have a nest of baby bird in the engine bay!
removed the fan,
Took me 6 Hours
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
