Happy New Year Friends,
I checked my Deli (in the right place) and I noted that the OEM tool kit was gone . Does anyone have any recommendations on a replacement jack?
Missing Tire Kit
- F0urEvrCaR22
- Vehicle: 1993 L300 Exceed Star Wagon Turbo D
- Lapprentis
Missing Tire Kit
Look for any parting out L300 on the advertized and you will find an original jack/tools. i do not know about in Japan but common here in Canada. Used internet searching tool : google, etc
Lapprentis
Lapprentis
- NewDelica91
- Vehicle: 1991 Delica L300 Starwagon
Missing Tire Kit
Try these links (see below). When I got my Exceed the kit was missing as well but it had been mostly replaced by local kit. A bottle jack and a 4 point tire iron. The remaining tools (screwdriver and wrench set) I picked up at Canadian Tire. Hopefully, you can get what you are looking for.
https://www.catalogs.ssg.asia/mitsubishi/?lang=en
https://www.megazip.net/
For this link enter your body number and it will match up to your vehicle. Also, I used this site to buy the weather seal for my sunroof. (https://www.amayama.com/en) I found later I could've gone to Greggs for the part but I learned.
Written from underneath my Delica, just kidding!
- feetforbrains
- Vehicle: 1991 Delica L300 Chamonix
Missing Tire Kit
Because the lift points are so far under the front I carry a 12 ton pump jack. Check you lift point clearances with your tire size and then get something that will fit and extend at 10 cm above resting point. More is better
Sent from my Pixel 2 using Tapatalk
- F0urEvrCaR22
Missing Tire Kit
Thanks for the info,
My intent is to switch to "Yokohama Geolander A/T (P253/75R15/108T/XL). Also, I intend to raise it about 3" in the future. So, the OEM Bottle Jack seem like it may not do the job. So, looking for something that is as close to being "future-proof" as possible, and something I can carry around in my car. What about this thing:
Powerbuilt 640912 All-In-One 3-Ton Bottle Jack with Jack Stand
https://www.amazon.com/Powerbuilt-64091 ... LZGFU?th=1
