So I'm trying to get a kit together for day trips and a kit for multiple day trip any suggestions? My vehicle did not come with the standard kit unfortunately. Any suggestions are greatly appreciated thanks in advance! Also looking for other pieces of kit that are good to have as well.
Toolkit and other bits for L300
- NewDelica91
- Vehicle: 1991 Delica L300 Starwagon
Written from underneath my Delica, just kidding!
It should be housed in the left rear pillar, just below the tail lamp, accessible from inside if you remove the trim panel. There should be an orange hydraulic jack, and a black vinyl bag with tools.NewDelica91 wrote:My vehicle did not come with the standard kit unfortunately.
I only mention this because I used to work for AAA and absolutely *no one* knew where the tool bag was in an L300. Even at the wrecking yards (where they remove tools from all vehicles and sell them separately for ridiculous prices) the L300s always have their tools. My own van came with some dodgy scissor jack and a motley collection of spanners, while the factory tool kit was in place, brand new, never touched.
Oh. Suggestions. 10, 12, 14mm spanners. Adjustable spanner. Pliers. Screwdriver with replaceable tips- #2 and #3 philips especially. A jack that has enough lift to change a tyre, and a wheel brace strong enough to get the wheel nuts off. Cable ties, insulation tape, duct tape. Rags.
- NewDelica91
When I went to check it before buying I checked for the tool kit and found a jack and the lever for the jack and nothing elseGrowlerbearnz wrote:It should be housed in the left rear pillar, just below the tail lamp, accessible from inside if you remove the trim panel. There should be an orange hydraulic jack, and a black vinyl bag with tools.NewDelica91 wrote:My vehicle did not come with the standard kit unfortunately.
- feetforbrains
- Vehicle: 1991 Delica L300 Chamonix
Add:
Spare fuel filter
Spare oil filter
http://www.landfallnavigation.com/rescu ... UkEALw_wcBRescue tape (for sealing pressure leaks, stuff has saved my bacon more than once)
Jumper cables
Pair of alligator clips (red and black)
Multimeter
PB Blaster
Spare fuel filter
Spare oil filter
Jumper cables
Multimeter
PB Blaster
- NewDelica91
My apologies for the noob question, what's a pb blaster?feetforbrains wrote:Add:
Spare fuel filter
Spare oil filter
Jumper cables
Multimeter
PB Blaster
Sent from my SM-G930W8 using Tapatalk
- feetforbrains
It's a breaker solution. Helps get rusted or stuck screws and bolts free.NewDelica91 wrote:My apologies for the noob question, what's a pb blaster?feetforbrains wrote:Add:
Spare fuel filter
Spare oil filter
Jumper cables
Multimeter
PB Blaster
https://www.amazon.com/gp/aw/d/B000I207 ... ref=plSrch
- NewDelica91
Ah[emoji362] thanks for clarificationfeetforbrains wrote:It's a breaker solution. Helps get rusted or stuck screws and bolts free.NewDelica91 wrote:My apologies for the noob question, what's a pb blaster?feetforbrains wrote:Add:
Spare fuel filter
Spare oil filter
Jumper cables
Multimeter
PB Blaster
- ACKO15
Flex head ratchet wrenches are a time saving godsend. Also, a good utility knife and all the other items mentioned. I carry along a small multi-purpose funnel and some brake cleaner as well.
