Still running Hot!
Still running Hot!
Postby Growlerbearnz » Tue Jun 27, 2017 3:07 pm
I just measured mine, the filler neck is 15.5mm from upper to lower sealing surface, the radiator cap 16.7mm. The radiator cap's lower seal has a clear impression of the sealing surface, so I know it's making contact.
I know you have a new radiator cap, but could it be faulty? Do you still have the old cap?
helibrian
Still running Hot!
Postby helibrian » Wed Jun 28, 2017 1:03 am
Did you burp the system when you change the water pump? I would check for exhaust gas in the coolant too.
Trinker
Vehicle: L300
Still running Hot!
Postby Trinker » Wed Jun 28, 2017 5:40 am
The system is very well bled, and I have two brand new rad caps. Next move will be a coolant exhaust gas test here...
92'L300 Chamonix - Fully camperized adventure rig 8-)
Trinker
Vehicle: L300
Still running Hot!
Postby Trinker » Thu Jun 29, 2017 12:14 am
It's the head, or head gasket... Popped off the cap when she was getting nice and hot, coolant was down well below the fill neck. Topped her off, sealed the rad cap back on and got a friend to rev the engine as I watched the outflow tube in the coolant overflow tank. When she's idling no bubbles, but when she's hot if you let it idle for ten seconds then rev it up to 3000rpm she burbs. And will do it time and time again..... :cry:
Still running Hot!
Postby Growlerbearnz » Thu Jun 29, 2017 2:38 pm
Bugger. Off with its head.
helibrian
Still running Hot!
Postby helibrian » Thu Jun 29, 2017 3:13 pm
I'm doing my head right now. It's a lot easier than I thought it would be just remember to label and bag everything so you know where it goes.
Trinker
Vehicle: L300
Still running Hot!
Postby Trinker » Fri Jun 30, 2017 12:14 am
Such is life, I just wanted to say thank-you to everyone who gave me in-put and advice on this thread and many others I have started. In particular Growlerbearnz, whoever you are, my hats off to you for everything you've contributed to this forum and helping me with this problem as well as many others. We will see where I go from here, but one of the best things about owning a Delica is having this forum as a resource, thanks everyone - Trinker :M
Morgonzo
Vehicle: L300
Still running Hot!
Postby Morgonzo » Fri Jun 30, 2017 6:29 am
Sad news trinker, good luck with the work ahead of you.
"Zowie Zow!" :-D
helibrian
Still running Hot!
Postby helibrian » Wed Jul 05, 2017 2:03 pm
I had basically the same problem and my head was not cracked just a blown head gasket. It cost 120$ and a few days work if you take your time. I did the seals in my turbo at the same time. If your timing belt, water pump and radiator is old it would be a good time to tackle that as well but the rad doesn't have to come out just drain the coolant from the thermostat or your engine will fill with coolant.
Trinker
Vehicle: L300
Still running Hot!
Postby Trinker » Thu Jul 06, 2017 9:42 am
When you say basically the same, what exactly did you have going on helibiran? I would love if it was just the gasket but I guess there isn't any way to tell until I start getting my hands dirty here. Once the head is pulled where would one bring it to get it checked? My understanding is some head cracks are so small they are hard to self diagnose?
helibrian
Still running Hot!
Postby helibrian » Fri Jul 07, 2017 12:03 am
My van was not blowing white smoke or losing coolant. It was pressurizing the coolant and was running ok it you only put the rad cap on to the first notch. I takes a few hours to get the head off. Take a look and see if your gasket is blown. Note there will probably be cracks around the fuel/ ignition port but that I'm told is normal.
john clem
Vehicle: 1992 delica
Still running Hot!
Postby john clem » Mon Jul 10, 2017 4:19 am
If coolant pushing out the rad fill hole with cap off continualy and cold at an idle, its definetely head gasket or crack letting combustion pressure to pass to cooling system, Cold engine at idle and cap hole plugged you shouldnt have pressure pushing into overflow tank yet, when warm, system will expand 15% and find right rad level and not expand further.
Trinker
Vehicle: L300
Still running Hot!
Postby Trinker » Tue Jul 11, 2017 2:35 pm
Yeah, I've accepted that my head cracked, even if not majorly. Just figuring out my next step here now
Trinker
Vehicle: L300
Still running Hot!
Postby Trinker » Tue Oct 03, 2017 7:57 pm
Well, the deed is done and the head has been replaced, took her for a couple of test drives and the I've finally managed to stop the temperature needles dashboard dance that has given me far too much anxiety. Now time to start working on some of the more routine maintenance, oh man...
Sylquebec
Vehicle: looking for a delica
Still running Hot!
Postby Sylquebec » Sat Oct 21, 2017 7:23 pm
You put a new head or you get yours rebuild?
Envoyé de mon SM-G903W en utilisant Tapatalk
Who is online
Users browsing this forum: Growlerbearnz and 5 guests
