leaking fuel pump
Flounder
Vehicle: 1991 Delica l300
leaking fuel pump
Postby Flounder » Thu Apr 13, 2017 8:29 pm
So I just changed where I get diesel from Super Store to Shell. Van is running much better already. Starts easier, smokes less, better mileage. HOWEVER since doing this my fuel pump is leaking. not sure exactly but thinking from the two bolt on plates on the side of pump. Is there any connection to fuel change to leak???????????? Note. never leaked before running other fuel.
JoeMag
Vehicle: L300 Crystal lite roof 5spd
leaking fuel pump
Postby JoeMag » Fri Apr 14, 2017 12:04 pm
Most of the time they will leak from the two plates at the bottom of the pump on both sides. there is also the seal at the back of the pump kind of between all the fuel lines. The latter can be replaced without taking the pump out of its hole but not the bottom ones.
Flounder
leaking fuel pump
Postby Flounder » Fri Apr 14, 2017 12:44 pm
Was thinking it was leaking from those plates. Is it just a gasket on each that need to be replaced?
JoeMag
leaking fuel pump
Postby JoeMag » Sat Apr 15, 2017 9:38 am
yep O rings actually.
Flounder
leaking fuel pump
Postby Flounder » Mon Apr 17, 2017 9:52 am
so with a little further investigating it appears that the pump is leaking from top gasket on engine side. Should I just have whole pump rebuilt?
leaking fuel pump
Postby Growlerbearnz » Mon Apr 17, 2017 2:42 pm
If you've pulled it apart that far you might as well buy a rebuild kit (http://www.ebay.com/itm/GASKET-KIT-REBUILD-KIT-VW-VE-Injection-Pump-Diesel-/331578370229?hash=item4d339c68b5:g:eEgAAOSwjVVVwlGs&vxp=mtr) and replace the seals yourself. I'm guessing you've seen the Gnarlodious VE pump rebuild how-to? http://gnarlodious.com/vanagon/bosch_pump/-Rebuild
Killbert
Vehicle: 91 Delica Chamonix
leaking fuel pump
Postby Killbert » Thu Apr 20, 2017 4:10 am
Oh man that looks exciting
Sent from my SAMSUNG-SM-G891A using Tapatalk
leaking fuel pump
Postby Growlerbearnz » Thu Apr 20, 2017 5:56 pm
Killbert wrote:Oh man that looks exciting
...for certain definitions of "exciting", yes ;-). I would have said "intimidating" or "terrifying", but having done the rebuild it's surprisingly easy.
muk138
Member's Photo Album: http://instagram.com/marcus_leite
Vehicle: Delica L300 Super Exceed
leaking fuel pump
Postby muk138 » Sat Apr 22, 2017 9:07 am
On this topic, I been trying to track down instructions for replacing the seals.
Anyone find anything posted or done this and willing to explain?
leaking fuel pump
Postby Growlerbearnz » Sat Apr 22, 2017 7:03 pm
Check out the Gnarlodious link in my previous post.
Who is online
Users browsing this forum: No registered users and 3 guests
