Crank Pulley (balancer) marks don't line up. Spun?
ynwa
Vehicle: L300 Starwagon TD
Postby ynwa » Sun Jan 01, 2017 11:38 am
I'm thinking the pulley has spun on the rubber but wondered what you all have to say. I'm attempting to set the pump timing and have the cam/pump marks lined up fine. However, the crank pulley mark is about 30deg advanced (before the case marks). This might sound short term but I was thinking to add a new mark on the pulley where TDC should be, then set the timing.
Think I'm looking at a new pulley? Them things are 'spensive...
This is how far out the cam mark is when the crank pulley thinks it's at TDC. Note that both the IP and Cam marks sync up just fine.
1991 L300 TD Low Roof
ynwa
Postby ynwa » Sun Jan 01, 2017 2:04 pm
Nevermind, my Delica dream appears to be over. Keyway shattered...
204explorer
Vehicle: l400
Postby 204explorer » Sun Jan 01, 2017 7:06 pm
Sorry to hear about your bad luck.
Postby Growlerbearnz » Tue Jan 03, 2017 8:54 pm
Damn. That's the end of that crankshaft. :-(
Morgonzo
Vehicle: L300
Postby Morgonzo » Wed Jan 04, 2017 11:27 am
That really sucks... :-( sorry this happened to your Deli. Are you going to try to fix it or are you totally fed up with it now?
"Zowie Zow!" :-D
ynwa
Postby ynwa » Mon Apr 17, 2017 9:36 pm
Whoops, sorry for not replying. Nope, I kept her going.
Pulled everything off, new sprockets, keys, harmonic balancer from Ebay. Set the new keys in and lathered everything in LockTite 660 (wow, pricey goop). Oh, and a new crankbolt of course. Torqued it all down and have been driving for a couple months now. :)
I'm not fooling anyone however. I plan on rebuilding the motor this summer while I have a 650GS to boot around in. Definitely not done yet!
Cheers! Seen lots of Deli's around Victoria. If you're out there holler. 'Specially the Tofino Bus getting work done at Prospect Auto. :)
Who is online
Users browsing this forum: No registered users and 4 guests
