no turn signals or 4 way flashers
captainfalcon
Vehicle: Yahama BWS
Post by captainfalcon » Sat Apr 28, 2012 8:59 am
I had the dash off the other day and was fiddling around running wires for my stereo. After potting everything back together and attempting to drive away bumping the new tunes I realized that my turn signals were not working. No clicking, nothing. Tried the hazard switch and nothing there as well. I tested both fuses and they are both good.
So I'm wondering if maybe I disconnected something while I was working under the dash, specifically under the steering column/radio area? I popped the dash off again and attempted to trace the flasher wire but there is nothing I can see.
Possibly 2 is that I have shorted out my flasher relay while wiring up this stereo.Is there any surefast way to diagnose this?
Cheers!
CVI
Re: no turn signals or 4 way flashers
Post by CVI » Sat Apr 28, 2012 9:04 am
Check your flasher unit connectors. You might have forgotten to reconnect them when you reinstalled the dash... :-D
CVI Automotive
JDM & Imported Vehicles Specialist
104-2353 Peardonville Road Abbotsford BC V2T 6J7
Phone: 604.710.7000 email: ati@atigroup.com.ph
Web: cviauto.com
captainfalcon
Vehicle: Yahama BWS
Post by captainfalcon » Sun Apr 29, 2012 2:23 pm
fantastic ill give that a go. Just to clarify, the connectors your talking about are the ones that come out of the steering column under the dash?
