Hello guys/gals
I have noticed during my night drives as I pull up to a stop my batt light, fuel filter light, and A/T light glow just ever so slight. If I raise the idle it goes out. I tested the battery, ok, then measured the voltage at the battery and at idle it is at 12.5v which is a volt low, but if you raise the throttle voltage jumps to 13.8v which is perfect. I also put on every electrical load. Tomorrow I will do a amp test percentage. Long story short I am pretty sure the alternator is on its way out, does anyone have a parts list for the alternator rebuild kit?
Thanks everyone
Dustin
alternator
- Vehicle: delica L300
alternator
Re: alternator
http://www.delica.ca/forum/help-not-sta ... 10299.html
I took mine to Brighouse in Richmond (they might be able to tell you exactly what is required to do it yourself) to have it rebuilt. It's a pain to take out but definitely do-able for an amateur mechanic like myself
