Original Paint Code
- Vehicle: PO5V
Original Paint Code
Hi all,
I am going to repaint my Delica. Please goto this link and see the Delica image. This is the exact color what i want to know about the exact color code. http://s689.photobucket.com/user/rightd ... c.jpg.html
Please help..
Expecting your fast replay..
Thank You
Asintha
Please help..
Thank You
Asintha
- niekt
- Vehicle: L300 4x4 2,5 TD
Re: Original Paint Code
hi Asintha,
Maybe these links help?
http://www.automotivetouchup.com/touch- ... ll-models/
http://www.automotivetouchup.com/paint- ... ubishi.htm
Niek
Niek
Niek
2001 L300 4x4 2,5 TD
- Growlerbearnz
- Vehicle: Delica P25W
Your paint code should be on the VIN plate in front of your drivers seat (under the carpet flap). This link will show you how to find it:
http://www.mdocuk.co.uk/forums/viewtopic.php?t=20060
- Vehicle: PO5V
Hi friends,
Thanks you for your reply, the thing is my Delica is totally red. So i want to change that color (Red) to where i was showing in my first post URL image. that is why i want the exact color codes of that particular attached URL picture (two color codes).
Please help..
Thanks and Regards
Asintha
Please help..
Thanks and Regards
Asintha
- niekt
aha, now i understand your question.... have you tried to browse the Delica photoalbum to see if one of our members has "your" color ? they should have the right paintnumbers on their identification plate.
Niek
- Big-Bird
- Vehicle: 96 PE8W Spacegear
In less than 5 minutes of searching I found these 2 listings and yes they are slightly different due to the year of publication. Search it and find your color.
http://www.vait.ua/files/Color%20Code/M ... mation.pdf
http://www.lackspray24.de/PDF/MITSUBISH ... mation.pdf
My money is on the G13 Timber Green used on the 2002 Delica Starwagon. Kaiser Silver if you see it is much darker than what you want and is used as the 2 tone color on many L400's
- Vehicle: PO5V
Hi Friends,
I am really appreciate your quick responses. Thank you so much for that, but still i am feeling my question was not solved. Your replies was really helpful, but among lot of color cods i am really messing up to find exact color codes what i want.
Please go to this link,
Hop you can see a Delica photo..
That is the exact color what i want.. So i am looking for that exact two color cods.. One of my friend told me those are G45 Debia and H81 Dupont colors is it true?
Help me to clarify my issue..
If anybody know the above URL image colors cods please let me know asap..
Thanks and Regards
Asintha
Thanks and Regards
Asintha
If you are not repainting the entire body, the paint has faded lots and won't match up. Ask me I tried with the green/grey colours.
TLWF
TLWF
- Vehicle: PO5V
Hi friends,
Yes, i am going to repaint entire body. first i remove the red paint then i apply new paints.
the problem is i still could not find the exact paint code what i want.
Thanks and Regards
Asintha
Thanks and Regards
Asintha
- Big-Bird
Two Tone Color Combination - F0A
A69, AC11169 Munich Silver Metallic/Satellite Silver Metallic
AC11176, F76 Alamoana Green Pearl/Navajo Green Pearl
AC17088, G88 Fiji Green
If someone has an L300 with the green / silver paint scheme in your photo they can verify the color I posted above. The other option is look it up yourself on a Paint Pantone sample deck. There a lots of white, grey, blue delicas in our membership...not that many green/grey.
- Vehicle: PO5V
Hi Friend,
Thanks you for your reply. Colors you have posted here are somewhat similar to what i want. lets see,
If any body can confirm the colors, that would be better, so then i can select those paint colors without any issue.
Thanks and Regards
Asintha
Thanks and Regards
Asintha
- Vehicle: PO5V
Hi friends,
Thanks all who have helped me to find proper colors. Finally i have selected two color cods, those are G 45 and H81. I hope these colors best fit to my Delica..
Thanks and Regards
Asintha
Thanks and Regards
Asintha
