you need to figure out why the cam seized....MattieB1 wrote:So I'm going to be replacing the head, cam, rockers, and valves. Anything else I should be looking into while its all apart to make sure this won't happen again?
If it oil starved you bottom end bearings will be toast or minutes away....before moving forward figure out what went wrong...good luck...
