hi!
this is my freshly imported L300 to quebec
im looking for any L300 newbie advices, tips.
thanks a lot!
Alex
L300 95' P35W diesel automatic
alexhercule
- Vehicle: L300 1995 P35W
- IMG_5356 copy.JPG (368.23 KiB) Viewed 5101 times
I noticed you posted with a dry Inclinometer. They are not hard to fix if it was like mine. Simply take the unit apart and refill with mineral oil. There is usually a crack in the flexible back you can coat with permatex gasket sealer. I used an orange color. it's been good for 10 years. Also check the attached post for some help.
http://delica.ca/forum/viewtopic.php?f= ... air#p22492
alexhercule
thanks! I took the whole unit apart. I will look for a crack and try to refill it. will let you know.lrp374 wrote: ↑Mon Dec 02, 2019 10:28 am I noticed you posted with a dry Inclinometer. They are not hard to fix if it was like mine. Simply take the unit apart and refill with mineral oil. There is usually a crack in the flexible back you can coat with permatex gasket sealer. I used an orange color. it's been good for 10 years. Also check the attached post for some help.
