2"lift and no idea whitch part #????
thelazygreenfox
Post by thelazygreenfox »
Yes longer brake lines are needed with a 2" lift as well as a longer differential vent line. Experiment with the front, you may need longer brake lines there as well. It's tricky to determine until after the lift.
I also connected a light spring to the rear brake line at a half way point to prevent it being pinched when the shock travel was at it's shortest. Your choice.
PM me if you want to talk about any of the above. Sometimes it's just difficult to put it all into a well worded explanation.
Green line sales, Venables St Vancouver sells brake lines and will make up as you wait.
Good luck
MD :-D
P.Gaudreault
Vehicle: Mitsubishi Delica 1998 Chamonix
Post by P.Gaudreault »
Here is the proper shock for 2'' lift kit...
Front: RS999029
Rear: RS999202
From this web site: http://www.4wd1.com/Delica.htm
I found this site before I buy my shocks but I didn't found the part num. Tonight I did find. I am very very very $#&*$ angry right now. Few hundred later..
I will have 4 Ranchos for sale, I'm sure they will be perfect for a 4'' lifted van..
